or detailed information on creating an AutoCAD Civil 3D point and a point label style please refer to the AutoCAD Civil 3D user documentation.
Below are the basic steps for creating a new point style.
A point style specifies the symbol that displays at the X Y location for the point in the drawing. The style can also specify scaling for the symbol and its appearance in 3D views.
To create a point style
- In Toolspace, on the Settings tab, right-click the Point Styles collection and pick New.
- In the Point Style dialog box, click the Information Tab. Enter a name and description for the point style.
- To define the symbol used to display the point, click the Marker tab. Specify the symbol type and options for size, scaling, and rotation.
- To define how the point displays in 3D views, click the 3D Geometry Tab. Specify the 3D Geometry settings.
- To define the display properties for the point style, click the Display Tab. Specify the dis-play properties for the symbol.
- To view summary information about the style, click the Summary tab.
- Click OK.
