Updating an AutoCAD Drawing Template
As with any AutoCAD work, having a configured drawing template can save considerable time. Customised geotechnical styles can be saved within a drawing template follow these simple steps:
New drawings can be created based on the saved drawing template; the new drawings will have the new or modified AutoCAD Civil 3D styles in them.
