From the OpenGround Cloud ribbon, click Strata to display the dialog box.
The Strata Manager is used to create and display strata surfaces based on the Band By selection.
The manager is designed to make it fast and easy to switch between strata surfaces, the display of each surface can be checked On or Off; there is no need to change the surface style to hide the surface.
The grid lists all strata as specified by the Band By option in the project and gives summary information for the various strata.
The grid can be sorted by clicking on the header of any column, clicking again will change the sort order.
The grid contents can be filtered by using the filter icon in the column header.
Band By: The banding option is used to specify the type of geotechnical data to be used to create the surfaces on. Changing the banding will not affect the current surfaces but will allow new surfaces to be created using the selected banding.
Include Base of Locations: Indicates if the last depth value from a location should be used in creating the strata surfaces, including the last value from a hole that may create inaccurate sur-faces. The last value from the hole, highlights the depth of the hole and not the depth of the base of the strata. For instance, in Trial Pits the geology will continue past the bottom of the Trial Pit. Toggle On Include "Base of Locations" will force the last value from the location to be used in creating surfaces.
Use the down arrow to control the display of both top and base surfaces independently.
