Step 1 : Setup Profile
Specifies how and what Geotechnical Profile to create.
Profile View
Note: Profile styles can be edited using the standard AutoCAD Civil 3D functionality, refer to Profile View Styles in the AutoCAD Civil 3D help
Geotechnical Surfaces
The grid lists all of the geotechnical surfaces currently created in the drawing. If a stratum surface is not present it means the surface has not been created, cancel the command and use the Strata Manager to create the required surface.
At least one geotechnical surface must be created and included to create a geotechnical profile.
Like all OpenGround Cloud related grids, the rows can be sorted and filtered by clicking on the column headings.
Each stratum is represented by a single row in the grid.
