Civils Extension Ribbon Interface
Data Management
Asset Management
Profile
XYZ
Point Group: A wizard to create a Civil 3D Point Group from down hole data, the Points can either be at true elevation or the actual value of the reading can be used as Z coordinate
Surface: Like Point Group, but creates a Civil 3D Surface from the down hole data.
Interpretation
Fence Diagrams
