The most powerful feature of the portal is the ability to queue data for importing into OpenGround CloudvProfessional.
This is particularly useful as the portal will validate the file for any errors which would prevent a full import, providing real time feedback to the user.
The ability to queue requires a specific user role which is added to a user’s security group. (system admins will do this) The role is called Queue Imports (see image below).
Once this role is added, any user can queue imports via the portal. To initial an import queue, select the project you want to import into and select Upload Data.
Select the file format, the appropriate mapping file and put a comment (mandatory). After entering a comment press start upload.
*Standard mapping files avaliable for OpenGround can be found here
The file should process and upload. When completed you will be greeted with one of three Results.
After the data has been queued, you can press finish or start another upload.
The File is ready to be imported into OpenGround Cloud Professional. To import the file, navigate to Manage Imports in OpenGround Cloud Professional. The files will be displayed in the dialog window, Press import to start the import process or download source data to download the file.
