Any Documents that are stored in the cloud against a Location within the project can be downloaded and viewed. Similar to OpenGround Cloud Professional, the document image will appear next to the location. Select the location and press the view documents button.
The documents grid will now open, this will display data on the document/s in question, to download press the download button. You can save this to wherever you wish.
To display a Quick Log, select a location and press the quick log button. The log will be displayed inside the Portal.
