Portal Map
The Map can be used to visualise the locations of boreholes for your projects, to view the project locations simply select View Project on Map from either the current project page or the project list.
The Map will be displayed with blobs corresponding to the project centroid and the borehole locations. The blue blob is the project the red are the locations; clicking on them will display tool tip meta data on the locations and the project.
