No Data Entry Profiles will be available for a project when you first download it so you will see a blank Profiles screen (as shown in figure a below).
To download a Data Entry Profile follow these steps:
- Tap the Download from Cloud icon
at the bottom of the screen (figure (a) below). - Tap on the required profile and then tap the Download from Cloud icon at the bottom of the screen.
- The profile will be added to your list of available profiles and removed from the visible screen. Tap the back icon at the top of the form to return to your profile list or repeat the above Step to download another profile.
