Before you can take pictures on collector please ensure, Camera and Storage permissions have been granted/enabled when prompted.
Photos can be captured directly through the app or attached to any record of data. This can be with either done through
Table/Summary View
After accessing the table view you can select the attach photos button on any specfic record of data, below is an example of adding photos to an SPT record. Photos can also be edited and removed via this interface.
Action Steps
After entering a record of data for certain fields, "action steps" may trigger to prompt users to take a photos similar to the below. These have been setup as default in your configuration pack or by your OpenGround Administrator. Please contact your OpenGround Administrator if you would like these to be customised.
