The Headers with "grid" ticked on will appear on the summary grid within the App. The order of these Headers can be different from the order of the fields on the form.
The order of Headers on the summary view is changed using the following steps:
Select the grid from the Data Entry Profile screen.
Select the Grid Order menu item as shown below.
Drag and drop the fields into the required order and click the close button in the top right of the screen.
