The IT Managers will need to ensure the following items are completed:
- Install the OpenGround Launcher under a user account with Administrator privileges. Further information
 - Check proxy exception requirements. Further Information
 - If the users require the Andriod Tablet logging solution, OpenGround Data Collector, then this should be installed on the tablet devices. Further Information
Minimum requirements for Android tablets
