Going back from the data entry for a location will return the user to the Shifts screen. Clicking the flag on the green, Active Shift will bring up the end of shift screen. Similarly to the Start shift, fields are currently hard-coded on this screen.
Viewing a quick log on a shift-supported location, will prompt to either view log for a given shift or to view a standard quick log.
