Important Note: Beginning with the CONNECT Edition, OpenCities Map is now a standalone product and is not available as a layered application for MicroStation. For further information, please refer to the question How can I upgrade from Bentley Map V8i to OpenCities Map CONNECT Edition? in the CONNECT Edition FAQ
The OpenCities Map product line includes the following:
OpenCities Map PowerView - For users that primarily need to view and perform light 2D feature acquisition and editing. OpenCities Map PowerView can query from spatial databases.
OpenCities Map Advanced- Designed for users that need to create, edit, manage, and analyze spatial databases. OpenCities Map Advanced can query, edit and post to spatial databases. The software can also perform long transactions with a two-tier connection to Oracle Spatial.
OpenCities Map Ultimate- Is designed for users that need all the functionality of OpenCities Map Advanced as well as the ability to execute advanced reality data processing with Bentley Descartes, and/or long transactions with a two-tier connection to Oracle Spatial. Bentley Descartes is included with OpenCities Map Ultimate. OpenCities Map Ultimate also supports full 3D editing.
| Theme | OpenCities Map Ultimate | OpenCities Map Advanced | OpenCities Map PowerView | Version Moniker |
| formerly: | OpenCities Map Enterprise | OpenCities Map | OpenCities Map PowerView | Included as of: |
| Reality Data Processing (Raster, Scalable Terrain Model - STM, Point Cloud and Reality Meshes) - Full Descartes version | Y | - | - | |
| 3D Placement and Editing tools | Y | - | - | |
| Animation creation | Y | - | - | |
| XFM 3D Smart Editing | Y | - | - | Update 3 |
| Export to LumenRT | Y | - | - | Update 5 |
| 3D Buffer | Y | - | - | Update 5 |
| 3D Split/Merge | Y | - | - | Update 5 |
| Posting to Spatial Data Sources (Oracle, SQL Server, File Geodatabase, PostGIS) | Y | Y | - | |
| Posting to Spatial Data Sources (ArcGIS Server and ArcGIS Online) | Y | Y | - | Update 4 |
| Exporting Geospatial Data (Shapefile, MIF, TAB, GML, FGDB) | Y | Y | - | |
| Export to MicroStation Elements, with or without Item Types (from Map Manager) | Y | Y | - | |
| Publishing to iModel (MicroStation) | Y | Y | - | |
| Geographic Coordinate System Management and editing | Y | Y | - | |
| Remap Tab from Save As dialog | Y | Y | - | |
| Linear Curves support | Y | Y | - | |
| Buffers and Overlay Analysis | Y | Y | - | |
| FME Integration | Y | Y | - | Update 3 |
| Topology Tools | Y | Y | - | |
| Design File Cleanup | Y | Y | - | |
| 2D Split / Merge | Y | Y | - | |
| DGN2DB to create spatial databases (Oracle and PostgreSQL/PostGIS) | Y | Y | - | Update 7 |
| Update Configuration | Y | Y | - | Update 16 |
| Update Features | Y | Y | - | Update 16 |
| Inference Rules | Y | Y | - | 2025 |
| Auto-promote | Y | Y | - | 2025 |
| Support for Bing Maps (see Deprecation Notice KB0046680 ) | Y | Y | Y | |
| Google Maps Background | Y | Y | Y | 2025 |
| Display of Reality Meshes, Point Clouds, Textures | Y | Y | Y | |
| Querying from Spatial Data Sources (WFS, Oracle, SQL Server, FGDB, PostGIS, ArcGIS, and ArcGIS Online) | Y | Y | Y | |
| Importing from Spatial Data Sources (WFS, Oracle, SQL Server, FGDB, PostGIS, ArcGIS, and ArcGIS Online) | Y | Y | Y | |
| Importing Geospatial files (Shapefile, MIF, TAB, GML) | Y | Y | Y | |
| Publishing to Map Mobile with the Map Mobile Converter | NLA | NLA | NLA | |
| Data Browser (Attribute & Property tables) | Y | Y | Y | |
| Data Capture and Maintenance | Y | Y | Y | |
| Join operations | Y | Y | Y | |
| Define Placement Method using existing key-ins (including 3rd-party apps) | Y | Y | Y | |
| Map Management and Thematic Mapping | Y | Y | Y | |
| Print Preparation / Print Model | Y | Y | - | |
| Python (Python Editor) | Y | Y | - | 2025 |
OpenCities Map Format Support
Listed formats and associated menu options are subject to the functional comparison chart above. e.g. 2D/3D functionality considerations.
Category [Import] |
| Geospatial File Types | Map Imports/Exports Dialog | Map Imports/Exports Dialog | Map Imports/Exports Dialog |
| Shapefile (*.shp) | Shapefile (*.shp) | Shapefile (*.shp) | |
| MIF/MID Files (*.mif) | MIF/MID Files (*.mif) | MIF/MID Files (*.mif) | |
| TAB Files (*.tab) | TAB Files (*.tab) | TAB Files (*.tab) | |
| GML Files (*.gml) | GML Files (*.gml) | GML Files (*.gml) | |
| Directory | Directory | Directory | |
| Oracle Spatial | Oracle Spatial | Oracle Spatial | |
| SQL Server | SQL Server | SQL Server | |
| ESRI FGDB | ESRI FGDB | ESRI FGDB | |
| WFS Server | WFS Server | WFS Server | |
| FME Import | FME Import | ||
| Common File Types | DWG (*.dwg) | DWG (*.dwg) | DWG (*.dwg) |
| DGN (*.dgn) | DGN (*.dgn) | DGN (*.dgn) | |
| Cell Library (*.cel) | Cell Library (*.cel) | Cell Library (*.cel) | |
| DGNLIB (*.dgnlib) | DGNLIB (*.dgnlib) | DGNLIB (*.dgnlib) | |
| Redline (*.rdl) | Redline (*.rdl) | Redline (*.rdl) | |
| Sheet (*.s) | Sheet (*.s) | Sheet (*.s) | |
| Text (*.txt) | Text (*.txt) | Text (*.txt) | |
| Image | Image | Image | |
| Exchange File Types | DXF (*.dxf) | DXF (*.dxf) | DXF (*.dxf) |
| CGM (*.cgm) | |||
| FBX (*.fbx) | FBX (*.fbx) | ||
| JT Format (*.jt) | JT Format (*.jt) | ||
| IGES (*.iges) | |||
| IFC (*.IFC) | IFC (*.IFC) | ||
| RFA (*.rfa) | |||
| STEP (*.stp) | |||
| Land XML (*.xml) | Land XML (*.xml) | ||
| 3D Modeling File Types | ACIS (*.sat) | ||
| 3DS (*.3ds) | 3DS (*.3ds) | 3DS (*.3ds) | |
| SketchUp (*.skp) | SketchUp (*.skp) | SketchUp (*.skp) | |
| 3DM (*.3dm) | 3DM (*.3dm) | 3DM (*.3dm) |
Category [Export] |
| Shapefile (*.shp) | Shapefile (*.shp) | ||
| Shapefile Directory | Shapefile Directory | ||
| MIF/MID Files (*.mif) | MIF/MID Files (*.mif) | ||
| TAB Files (*.tab) | TAB Files (*.tab) | ||
| TAB Directory | TAB Directory | ||
| CSV Files (*.csv) | CSV Files (*.csv) | ||
| CSV Directory | CSV Directory | ||
| GML Files (*.gml) | GML Files (*.gml) | ||
| ESRI FGDB | ESRI FGDB | WFS Server | |
| DGN file | DGN file | ||
| FME Export | FME Export | ||
| Common File Types | 2D / 3D | 2D / 3D | 2D / 3D |
| Export with Display Rules | Export with Display Rules | Export with Display Rules | |
| DWG (*.dwg) | DWG (*.dwg) | DWG (*.dwg) | |
| Design Library (*.dgnlib) | Design Library (*.dgnlib) | Design Library (*.dgnlib) | |
| V8 Format Design (*.dgn) | V8 Format Design (*.dgn) | V8 Format Design (*.dgn) | |
| Visible Edges (*.hln) | |||
| Exchange File Types | PDF (*.pdf) | PDF (*.pdf) | PDF (*.pdf) |
| CGM (*.cgm) | |||
| Collada (*.dae) | Collada (*.dae) | Collada (*.dae) | |
| DXF (*.dxf) | DXF (*.dxf) | DXF (*.dxf) | |
| IGES (*.iges) | |||
| STEP (*.stp) | |||
| OBJ (*.obj) | |||
| Parasolids (*.x_t) | |||
| Stereolithography (*.stl) | |||
| Visualization File Types | Google Earth (*.kml) | Google Earth (*.kml) | Google Earth (*.kml) |
| Luxology (*.lxo) | |||
| SVG (*.svg) | |||
| U3D (*.u3d) | U3D (*.u3d) | U3D (*.u3d) | |
| VRML (*.vrml) | |||
| VUE (*.vob) |
