Version 10.17.02.48
The following issues have been corrected and/or added to the OpenCities Map CONNECT Edition Update 17.2, version 10.17.02.48, dated February 23rd, 2023.
Compare the reference number from your service request below to determine whether a given issue has been resolved in this release.
| Reference | Summary Description | Keyword(s) |
| 751961 | V8i Task Navigation: V8i Dialog Mode does not respect Save Settings | User Interface |
| 752105 | Inference Rules dialog enhancements (Add Feature) (Edit Feature) | User Interface |
| 752106 | Schema Location dialog enhancements | User Interface |
| 862388 | Data Browser - Oracle - Inability to search domain text with filters active | Data Browser |
| 872746 | Geospatial Administrator - Macros - %lock operator for exported workset variable locking | GSA |
| 894175 | Inference Rules - properties not present in schema display in red | Inference Rules |
| 897804 | Support of FME Desktop 2022 | Interoperability |
| 941030 | Fixed: Regional Settings formatted double values requires: MS_GEO_USE_REGIONAL_NUMERIC_NOTATION | Data Browser |
| 915001 | Ribbon - Collaborate - Modeling, Visualization workflows added | User Interface |
| 970439 | XfmLocateOp bug with UORs during copy across references | API / SDK |
| 982290 | Graphical source names: display of underscore within name | User Interface |
| 985201 | MapManager - .NET Framework exception | File |
| 992707 | MapUltimate for Finland - Boundary dimensions - Dimension text | Dimensions |
| 992712 | MapUltimate for Finland - Coordinate Cross text justification | GCS |
| 1000547 | MapUltimate for Finland - subfeature use for Area Calculation Paper and Create Estate | XFM |
| 1002918 | MapUltimate for Finland - KTJImport - Program crash when defined source file doesn't exist | Data Transfer |
| 1004781 | Feature Definitions - pane titles and grid column naming | User Interface |
| 1014811 | Crash upon second or subsequent file open operations | File |
| 1015591 | Map PowerView - Element Template Association icon | User Interface |
| 1023158 | Insert vertex command fails with map manager labeling enabled | Map Manager |
| 1041959 | MapUltimate for Finland - Create Estate support of nested area features | XFM |
| 1035943 | Invalid XFM root feature - Allow deletion of invalid XFM feature instance | XFM |
| 1037564 | Column names using Danish characters are empty | Data Browser |
| 1040369 | ESRI "unexpected JSON property name" | Interoperability |
| 1041959 | MapUltimate for Finland - Mapreffi.ini - map name - increased prefix / suffix length | Settings |
| 1044404 | Expanded ProjectWise Integration capabilities | ProjectWise |
| 1048886 | Inference Rules - property rename results in exception | Inference Rules |
| 1052726 | Data Browser - simultaneous Copy / Paste of multiple values | Data Browser |
| 1052920 | OLE Object broken upon modification (move) | OLE |
| 1055144 | GDAL update | Security |
1059710
Save as DGN - corrupted label formatting
| Manipulation |
| 1062505 | Data Browser filter- Invalid Filter Expression (integer) | Data Browser |
| 1065207 | Generate XFM polygon by flood | API / SDK |
| 1068189 | EPSG:4269 Shapefile Geographic - Reprojected failure | GCS |
| 1069132 | Removal of individual ad-hoc connection | Spatial |
