- OpenCities Map CONNECT Edition Update 17.1
Resolved Issues
Version 10.17.01.25
The following issues have been corrected and/or added to the OpenCities Map CONNECT Edition Update 17, version 10.17.01.25, dated October 28th, 2022.  Review your Service Request and the Reference # below to see if it has been fixed in this release.
Reference Summary Description Keyword(s)
751333 Added the capability for multiple spatial database connections Interoperability
752519 Fixed an issue when using the Change Element Attributes command Grids & Graticules
755769 Geospatial Administrator connection to Oracle Spatial error with a specific workflow GSA
807340 Fixed a PropViewer issue that resulted in a VBA Interface error geo_example
808254 Import using the Schema Graphical Source GSA
845550 Inference Rules - Fixed an icon size issue Inference Rules
862392 Cannot copy and paste domain value Data Browser
869826 The Collaborate tab must be available in the Map and Map Modeling workflows Ribbon
888209 The Quick Element Info is not working in OpenCities Map, works in MicroStation Platform
950126 Export to GML fails when using a UNC named network folder Import/Export
959146 The About MicroStation item in the Ribbon shows the OpenCities Map version Ribbon
961843 Some feature properties are not shown when Danish Characters are used Element Information
964212 Feature Definition - Reduce pane size, delete feature, results to an exception Feature Definition
964804 Polygons with holes get corrupted when using a specific workflow XFM
969250 WFSX file compatibility issue "Error while reading ECSchema 'WFS_Schema..." WFS
975765 Post of a line feature is failing with this specific dataset ArcGIS
975775 In the Map Connections dialog for a Registered Connection, the Token appears twice ArcGIS
982288 Multi-connection features with the same name are not handled properly in the GSA GSA
982418 Import listing all the features from the database should only list Registered Features GSA
982419 Exception: The requested File Geodatabase is already open and in use GSA
982584 An ArcGIS v Map Update 16 results to an Exception in Map Update 17 ArcGIS
989497 Make Active for Edit (Reference) is not available in Map PowerView Reference
995749 Creating a sequence in the GSA is failing with error "failed to create ID generator" Spatial
998569 Store last value set to dgnFile not working anymore when re-loading the DGN file XFM
