Version 10.17.00.156
The following issues have been corrected and/or added to the OpenCities Map CONNECT Edition Update 17, version 10.17.00.156, dated July 25, 2022. Review your Service Request and the Reference # below to see if it has been fixed in this release.
| Reference | Summary Description | Keyword(s) |
| 752095 | Related to Platform BUG 660657 - [Save As] Remapping by CSV File crash with file containing MS Polygon collection | Import/Export |
| 752134 | (MAPCE) Plots with lower WMS raster resolution, takes longer to generate, excessive WMS network traffic | Raster |
| 780960 | [PostGIS] Add capabilities in OpenCities Map to utilize SSL enabled PostgreSQL/PostGIS instance from Azure. | Spatial |
| 889104 | Fence File on Reference polygon loses the level assignment | Reference |
| 905238 | The "Reload the configuration" command is not updating the Features Plot Scales | Update Config |
| 906591 | Line style settings notification problem after closing the Map application | Exit |
| 908359 | Inference Rules - Selecting all rules using the column header "*" shows an exception | Inference Rules |
| 908431 | Infer Values and assign values - Select All rows does not disable/enable all the rows | Inference Rules |
| 851784 | GSA can get out of synch when re-registering a spatial matched feature | GSA |
| 852731 | Inference Rules - Edit is available for Multiple row selection, but confusing since only one row is updated | Inference Rules |
| 914141 | Exporting to a GML file no longer works like in Bentley Map V8i | Import/Export |
| 897898 | Raster Manager XMWS attachment causes Application to hang indefinitely - reprojection - custom CS "S34S' and DKTM3 | Geographic Coordinate System |
| 751940 | Template of element properties is "none" | Print Preparation |
| 911047 | VBA CreatePropertyHandler fails for some elements in a specific dataset | Programming |
| 910513 | Command Manager dialog not opening from Ribbon with specific XFM schema | Administrator |
| 930834 | Exception on Feature Write with GetFloodBoundary, in Feature where element type changes | XFM |
| 930078 | Not able to import GML data | Import/Export |
| 751299 | Enable the WMTS feature aspect in OpenCities Map | WMTS |
| 888122 | Buffer and Overlay operation not working in a Map Model | Buffer Zone |
| 931476 | When the action "Add to Selection Set" is executed from the Map Manager, only the feature in the active model are selected | Map Manager |
| 751981 | Conditions on a level from a Reference are lost after using the Apply button | Inference Rules |
| 752423 | Exception: Type 'urn:gugik:specyfikacje:gmlas:modelPodstawowy:1.0:BT_IdentyfikatorPropertyType' is not declared received while importing GML File | Import/Export |
| 927772 | Default browser for Analyze Results Window should be changed from Internet Explorer | Analyze |
| 939609 | [ESRI File GeoDatabase] SEHException when connecting | Spatial |
| 939114 | Update Schema using the Map definition brakes the feature symbology order | Inference Rules |
| 940529 | Exception results when using same feature name than already exiting native feature | Inference Rules |
| 938373 | WFS Error "Invalid PROPERTYNAME" produced by URLs that worked in the previous version | Spatial |
| 950414 | Added the Labeling commands in Technical Preview | Installation |
