Version Information
This page contains information about OpenCities Map CONNECT Editions: version numbers, release dates, Subscription Entitlement Services.  Bentley Map V8i (32 bit) versions, dependencies, and prerequisites are included for reference, but are no longer supported as-of January 2022.  32-bit editions of Bentley Map are now supplanted by the 64 bit versions, known initially as OpenCities Map CONNECT and subsequently as OpenCities Map 2023.
CONNECT Edition generation:
The following table lists OpenCities Map CONNECT Editions which are built with the Power Platform. Power Platform is the MicroStation core application that underlies the CONNECT Edition products that are based on MicroStation.  Once a feature or fix is added to the Power Platform, it is available to all the applications based on the Power Platform.  This has increased consistency between applications, is fundamental to the Bentley update schedule and is part of an ongoing plan to unify similar tools and functions across Bentley applications.
Important note regarding OpenCities Map for MicroStation:  Beginning with the CONNECT Edition, OpenCities Map is now a standalone product and is not available as a layered application for MicroStation CONNECT.
For Bentley Map the V8i (SELECTseries) editions are no longer supported.  Please refer to the question How can I upgrade from V8i to CONNECT Edition? in the Map CONNECT Edition FAQ
Important note regarding licensing:  Starting with OpenCities Map CONNECT Edition x64 10.02.00.xx, licensing is handled with Subscription Entitlement Service, which does not use activation keys. Products with Subscription Entitlement Service are indicated with (SES). To enhance security, the licensing requires that you become registered in Bentley User Management and then sign in with those credentials to access the application. For more information regarding licensing, please refer to Subscription Entitlement Service (formerly CONNECT Licensing). For detailed instructions on the user registration and sign-in process, refer to Bentley User Registration and Sign-in.
Dates are in Year-Month-Day format.
NOTE: Beginning in August, 2021 the OpenCities Map Update numbers had been adjusted to match the Power Platform Update values.  The next update after OpenCities Map Update 7.1 is OpenCities Map Update 16; there were no Map Updates between 7.1 and 16.  Use the Bentley Software Downloads page to search for and download the version that you are licensed for.
DateRelease
Power Platform
Version
Descartes for
Map Ultimate
Notes
2023-02-23OpenCities Map CONNECT Edition x64 (SES) 10.17.02.48 Update 1710.17.02.45010.17.02.61Resolved Issues
2202-11-10OpenCities Map CONNECT Edition x64 (SES) 10.17.01.29 Update 1710.17.01.57810.17.01.54Security Release
2022-07-05OpenCities Map CONNECT Edition x64 (SES) 10.17.00.156 Update 1710.17.00.98110.17.00.155
2022-06-02OpenCities Map CONNECT Edition x64 (SES) 10.16.03.12 Update 1610.16.03.3410.16.03.07
2022-02-02OpenCities Map CONNECT Edition x64 (SES) 10.16.02.14 Update 1610.16.02.25310.16.02.16Security Release
2021-10-10OpenCities Map CONNECT Edition x64 (SES) 10.16.00.60 Update 1610.16.00.8010.16.00.80
2021-08-11OpenCities Map CONNECT Edition x64 (SES) 10.16.00.45 Update 1610.16.00.8010.16.00.80Resolved Issues
2021-03-18OpenCities Map CONNECT Edition x64 (SES) 10.07.01.09 Update 7.110.15.01.2310.15.01.23Resolved Issues
2020-06-23OpenCities Map CONNECT Edition x64 (SES) 10.06.00.05 Update 610.14.00.10910.14.00.109Resolved Issues
2020-04-14OpenCities Map CONNECT Edition x64 (SES) 10.05.00.51 Update 510.14.00.10510.14.00.105Resolved Issues
2019-11-04OpenCities Map CONNECT Edition x64 (SES) 10.04.00.42 Update 410.13.00.4810.13.00.48-
2019-09-27OpenCities Map CONNECT Edition x64 (SES) 10.04.00.41 Update 410.13.00.4810.13.00.48Resolved Issues
2019-08-23OpenCities Map CONNECT Edition x64 (SES) 10.04.00.35 Update 410.13.00.4810.13.00.48Resolved Issues
2019-04-16OpenCities Map CONNECT Edition x64 (SES) 10.03.00.26 Update 310.12.00.4010.10.00.40-
2019-03-25OpenCities Map CONNECT Edition x64 (SES) 10.03.00.23 Update 310.12.00.4010.10.00.40Resolved Issues
2018-11-22OpenCities Map CONNECT Edition x64 (SES) 10.02.00.18 Update 210.11.00.3810.09.00.38Resolved Issues
2018-07-31OpenCities Map CONNECT Edition x64 10.01.00.22 Update 110.10.00.2410.08.00.23Resolved Issues
2018-03-16OpenCities Map CONNECT Edition x64 10.00.00.3010.08.00.41N/A
V8i generation:
*Important Note - Bentley V8i (SELECTseries) product support was discontinued on January 1, 2022.  Further use of these products is not recommended, but not prohibited.
The following tables lists the Bentley Map V8i (SELECTseries) versions with their corresponding MicroStation version they were released with.
It's important to combine the Bentley Map V8i (SELECTseries) "For MicroStation" edition with its corresponding MicroStation version.  This allows you to take advantage of changes that were introduced into each product during the update cycle.  V8i (SELECTseries) generation products should be installed together.  However, within (SELECTseries) product release, newer versions of Bentley Map are compatible with older versions of MicroStation.  In some cases, older versions of Bentley Map are compatible with newer versions of MicroStation.  To maintain the integrity and supported functionality, the corresponding version of MicroStation should be installed at the same time.
Dates are in month/day/year format.
The updated version of Bentley Map V8i (SELECTseries 10) provides new flexibility for organizations that require Windows 10 Readiness and privacy and security compliance while they sequence their upgrade to the CONNECT Edition.
Bentley Map V8i (SELECTseries 10) is a simple and transparent installation for Bentley Map V8i users with no file format change with complete fidelity of existing workspaces and MDL customizations. Bentley Map V8i (SELECTseries 10) consolidates all enhancements and updates of previous SELECTseries releases and offers an extended support period for V8i users:
This version only includes Subscription Entitlement Service (formerly known as CONNECT Licensing) for users who have chosen to delay upgrading to the latest OpenCities Map CONNECT Edition.  Subscription Entitlement Service is not supported by SELECT activation key(s). Subscription Entitlement Service  features new behavior to enhance your organization's user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
We recommend that you install the latest version of OpenCities Map CONNECT Edition (*). But, if your organization needs more time to sequence your CONNECT Edition upgrade, Bentley Map V8i (SELECTseries 10) provides additional flexibility and ensures you can continue to use supported software. Bentley Map V8i (SELECTseries 10) offers these capabilities:
 Bentley Map V8i (SELECTseries 10) was initially only available as a stand-alone product. Beginning in May 2020 the product may once again be purchased and downloaded for use For MicroStation.
The available products are now: Map V8i (SELECTseries 10) Standalone, Map V8i (SELECTseries 10) For MicroStation, and the Map CONNECT edition.
The policy of trading-in a license is no longer necessary, but may be beneficial to some Users:
If you own MicroStation V8i and Bentley Map for MicroStation V8i you have two choices:
You can decide to exchange your Bentley Map for MicroStation V8i  license for a OpenCities Map Advanced CONNECT Edition license.  There is no cost for this license exchange however the price of SELECT will increase.
Or, you can decide to exchange both the MicroStation V8i and Bentley Map for MicroStation V8i licenses for one license of OpenCities Map Ultimate CONNECT Edition.  There is no cost for this exchange, however the price of SELECT will increase
Map stand-alone contains both Map and MicroStation commands found In the layered application.
(*) The CONNECT Edition of Bentley Map has been renamed to OpenCities Map.
Date
ReleaseNotesDependenciesPrerequisites
2020-06-24
Bentley Map For MicroStation V8i (SELECTseries 10) (SES) 08.11.09.923
-MicroStation 08.11.09.919Included
2020-05-08
Bentley Map For MicroStation V8i (SELECTseries 10) (SES) 08.11.09.920
2020-04-05
Bentley Map V8i (SELECTseries 10) (SES) 08.11.09.920
2019-12-19
Bentley Map V8i (SELECTseries 10) (SES) 08.11.09.914
2019-07-08
Bentley Map V8i (SELECTseries 10) (SES) 08.11.09.908
2018-04-13
Bentley Map V8i (SELECTseries 4) 08.11.09.882 Update 10
Resolved IssuesMicroStation 08.11.09.867Included
2017-08-18
Bentley Map V8i (SELECTseries 4) 08.11.09.862 Update 8
Resolved IssuesMicroStation 08.11.09.862Included
2017-04-21
Bentley Map V8i (SELECTseries 4) 08.11.09.836 Update 7
2017-03-07
Bentley Map V8i (SELECTseries 4) 08.11.09.834 Update 6
2016-12-01
Bentley Map V8i (SELECTseries 4) 08.11.09.805 Update 5
2016-07-18
Bentley Map V8i (SELECTseries 4) 08.11.09.763 Update 4
Resolved IssuesMicroStation 08.11.09.838Included
2016-03-24
Bentley Map V8i (SELECTseries 4) 08.11.09.713 Update 3
Resolved IssuesMicroStation 08.11.09.829Included
2015-12-11
Bentley Map V8i (SELECTseries 4) 08.11.09.666 Update 2
Resolved IssuesMicroStation 08.11.09.752Included
2015-05-04
Bentley Map V8i (SELECTseries 4) 08.11.09.615 Update 1
Resolved IssuesMicroStation 08.11.09.714Included
2014-11-13
Bentley Map V8i (SELECTseries 4) 08.11.09.503
MicroStation 08.11.09.614Included
2012-09-17
Bentley Map V8i (SELECTseries 3) 08.11.09.107
MicroStation 08.11.09.35708.11.09.03
2012-05-31
Bentley Map V8i (SELECTseries 3) 08.11.09.91
Product ID's Changed
2011-04-13
Bentley Map V8i (SELECTseries 2) 08.11.07.434
MicroStation 08.11.07.44308.11.07.03
2010-05-25
Bentley Map V8i (SELECTseries 1) 08.11.07.113
MicroStation 08.11.07.17108.11.07.03
2009-12-18
Bentley Map V8i (SELECTseries 1) 08.11.07.87
2009-03-16
Bentley Map V8i 08.11.05.49
MicroStation 08.11.05.1708.11.05.05
