| Reference | Summary Description | Keyword(s) |
| 818381 | Plot Scales label was set to English during Create New Workspace node, should have been Imperial | Geospatial Administrator (GSA) |
| 1080329 | Override Cell Symbology is not applied properly on point cell | XFM |
| 1088010 | Updated the OGR Library to the latest available version | Interoperability |
| 1097046 | Remove the "Include in Command Manager menu" checkbox from the AutoPromote item | GSA |
| 1097153 | Correct the loss of the element display during AutoPromote when a Map Definition is active | AutoPromote |
| 1101204 | Corrected a crash in a user-developed workaround during model change events | Configuration Variables |
| 1102737 | Override Cell Symbology setting is now honored | GSA |
| 1102986 | Complex Line elements were not set at the expected symbology | AutoPromote |
