| Reference | Summary Description | Keyword(s) |
| 1102737 | Override Cell Symbology is not honored in OpenCities Map Update 6. | Geospatial Administrator |
| 818381 | Change incorrect Plot Scale label, use Imperial to replace English or Local equivalent language. | Geospatial Administrator |
| 1113232 | Symbology keys added in the Fill Type Details Section are not honored. | Geospatial Administrator |
| 1106227 | Connecting to a PostGIS spatial table with multiple geometry columns results in exception. | PostGIS |
| 1103537 | Timestamp data type field is not visible while registering features using PostGIS connection. | PostGIS |
| 1095766 | Map connections to Oracle Spatial becomes unresponsive if Domain list definition has 'Dynamic Update' option enabled. | Oracle Spatial |
| 1113163 | Oracle data with working units in feet and inches positioned incorrectly after queried from OpenCities Map CONNECT. | Coordinate System |
| 1113074 | Referenced Shape file is incorrectly positioned if Working Units selected as Inches in CONNECT Edition. | Coordinate System |
| 1108185 | Saving SQL Server data into CSV format results an error "The property is null in ECInstance" | Data Browser |
| 1103349 | Load By Selection on new features from spatial database results into 0 records. | Data Browser |
| 1108915 | PBA definition of the annotation becomes corrupted when updated in the CONNECT Edition. | Annotation |
| 945952 | 'Named Boundaries' option in View tab is unavailable from CONNECT edition. | Ribbon |
| 1062089 | Add capability in Analyze tool to search for specific feature in 3D. | 3D |
| 1113243 | Overlay analysis performed on Linear- Polygon elements will provide unexpected results in CONNECT edition. | Topology Analysis |
