The following issues have been corrected in the OpenCities Map CONNECT Edition Update 7.1 versions of the products:
| Reference | Summary Description | Keyword(s) |
| 1122210 | Fixed a crash issue when Add Rectangular Viewport tool is used while changing the scale | Print Preparation |
| 1121944 | Fixed an Open File issue when Dynamic Feature Scoring is enabled | XFM |
| 1121797 | Fixed an intermittent issue when Other Elements layer is missing after creating a Map Definition | Map Manager |
| 1124245 | Fixed the Generate Thematic Classes by Property valued for Reference files | Map Manager |
| 1124028 | Fixed a problem in Locate/Highlight in the Data Browser for Reference files | Data Browser |
| 1119685 | Fixed the SET EXECUTION DIR variable in DGN2DB to honor spaces in the path | Spatial |
| 1121097 | Moved the PostSQL exe path to the DGN2DB batch file, from the Masterload.bat file | Spatial |
| 1122789 | Fixed an issue with the Export command for Polygon Collections | Export Feature Definitions |
| 1119703 | Reworked the Export Feature Definition key-in | Export Feature Definitions |
| 1121529 | Symbology does not recognize some values for inferred features which are defined by Rules | Dynamic Feature Inference Rules |
| 1121929 | Provided an option in in the GSA's Export Schema for the LiveFeatureRules.xml file | Dynamic Feature Inference Rules |
| 1122426 | Fixed blank display name in the Rules feature list | Dynamic Feature Inference Rules |
| 1122785 | Added a new MapManager public API function (xfmMapLayer exportMapModelFeaturesToStandardElements(Ex) | SDK/API |
| 1123611 | Removed CityGML from the Technology Preview options | Installation |
| 1122193 | Removed Dark Theme from the Technology Preview options | Installation |
