| Reference | Summary Description | Keyword(s) |
| 1076946 | Map queries were not respecting GDI Valid Time Setting when querying Workspace Manager Valid Time layers from Oracle 19c | Spatial |
| 1076541 | WFS spatial layer extents were not in the correct location when using projected coordinate systems |
Spatial |
| 1074937 | Chinese characters were not displaying properly in the Imports/Exports dialog |
Interoperability |
| 1074657 | Split 3D polygon collections were not being moved as a collection |
3D |
| 1074413 | XFM named criteria for domain lists were not being processed correctly when expression used featureAlias:propertyName |
Geospatial Administrator |
| 1073151 | Importing shapefiles was giving incorrect graphical results with specific geospatial coordinate systems |
Interoperability |
| 1073057 | Feature registration from Oracle 19c was not prompting for composite surfaces |
Spatial |
| 1072320 | Feature registration for PostGIS was resulting in an error |
Spatial |
| 1071078 | Request to add Port entry in connection dialog |
Spatial |
| 1069975 | Selective override for cells was not working as expected |
Map Manager |
| 1067704 | When using ArcGIS Feature Server, unable to cast object of type System.DateTime to System.String |
Spatial |
| 1064862 | Errors reading integers when using Esri sample servers |
Spatial |
| 1064125 | Under certain conditions, previously queried features could be modified without making a DB connections |
Spatial |
| 1063730 | Under certain conditions a crash would occur when compressing the file |
Crash |
| 1054206 | Data Browser was not displaying proper float precision values when working with SQL Server |
Spatial |
| 1050566 | Data Browser was retuning errors when using specific spatial criteria |
Spatial |
| 1041833 | Map Join Add key-in was resulting an exception error in the Message Center |
Spatial |
| 1034091 | Some print preparation functions did not cancel with the Reset button |
Print Preparation |
| 1031502 | Load by Selection into Data Browser was failing with SQL Server |
Spatial |
| 939428 | Print Preparation legend options should respect feature display in Map Manager |
Print Preparation |
