The following issues have been corrected in the OpenCities Map CONNECT Edition Update 16 versions:
| Reference | Summary Description | Keyword(s) |
| 414109 | Data Browser would not recognize Properties from Spatial databases, from a Select Set | Spatial |
| 414900 | Zoom Scale did not update when Features were not in the View | Zoom Scale |
| 416022 | Fixed the MS_GEOIMPORT_PATH variable | Interoperability |
| 474690 | Fixed the Text Priority issue where default value of -5,500 was set in Annotation | Annotation |
| 793768 | Added a variable to define the Spatial Location for Data Export | Interoperability |
| 923437 | Map Mobile Publisher and the Data Browser now use the Edit Column in combo boxes | Map Mobile |
| 934820 | Fixed Tool Box and Task Navigation errors when icons were missing | Settings |
| 977509 | Fixed the menu bar in the Geospatial Administrator (GSA) for foreign languages | GSA |
| 1033771 | Fixed a problem when a String with a comma errored when saving to .csv file | Browser |
| 1054304 | Fixed the Latitude/Longitude display in the Auxillary Coordinate Readout pane | Settings |
| 1061781 | Text was not scaling correctly when changing Drawing Scale | PBA |
| 1072323 | Spatial Unlock was incorrectly reporting that Features failed to lock | PostGIS |
| 1013571 | ArcGIS Connect dialog box needed resizing for the Server URL label | Internationalization |
| 1111905 | Provided the option to select a default favorite template with the MS_GEOPRINTPREP_FAVORITE variable | Print Preparation |
| 1113591 | Fixed an issue when defining multiple spatial view in the GSA | PostGIS |
| 1114632 | Added the capability to create DB Properties when using DB Linkages | Export Feature |
| 1115231 | Fixed a Post issue where the spatial table without a value for the CLOB column fails | Oracle Spatial |
| 1115472 | Made the "Update Command Manager List" command automatic | GSA |
| 1119187 | Replaced the Admin Workflow from MicroStation in the Map products | Ribbon |
| 1119237 | Fixed an issue when ArcGIS returned double.NaN for a missing Z ordinate | GeoECSDK |
| 1121769 | Now allowing more than one Place by Command Keyin method | GSA |
| 1121789 | Technology Preview items are now installed by default in the Configure page | Installation |
| 1122202 | Fixed the issue were the Layers would become 'unknown' after closing DGN File | Map Manager |
| 1123497 | Style and Scale are not considered for Text Features, and have been removed from XFM and Export to Schema | XFM |
| 1123823 | Import Shapefile was failing when Fence or View spatial extent was used | Interoperability |
| 1124426 | Fixed an issue with a specific dataset where Query a specific feature got caught in a loop | ArcGIS |
| 1124869 | Updated the GSA for Workset and Workspace where Project was used | GSA |
| 1126301 | Load By Selection to the Data Browser for spatial databases has been fixed | Browser |
| 1126309 | Using an ad hoc connection the data browser returns an error when using a where clause | Spatial |
| 1126319 | Correctly translated the Connect tab for an ArcGIS Connection | Internationalization |
| 1126320 | Correctly translated the User and Service Name for an Oracle Connection | Internationalization |
| 1126743 | Fixed a memory leak attaching a specific Cell Library | Memory |
| 1126859 | Fixed the symbology dialog where point-text features would allow zero or neg scale | Symbology |
| 1126909 | Fixed a WFS Connection issue where a query would complete, but return no features | WFS |
| 1127013 | Fixed the ArcGIS Server connection where some URLS would cause Exceptions and report "Invalid URL Code:400" and "Token Required" | Spatial |
| 1127356 | Fixed Add/Insert Rows for Domain List values | GSA |
| 1127376 | Made the Create New Workset and Edit Workset Parameters dialogs resizable | Save Schema |
| 1127893 | Fixed an issue where VBA was failing with a Print Preparation object | Print Preparation |
| 1127893 | Fixed an invalid geometries problem with a specific ArcGIS connection | ArcGIS |
| 1128040 | Fixed a Query issue when clicking info about a previously attached coordinate system | Coordinate System |
| 1128591 | Fixed an issue in the Data Browser when an attribute is named FKT in a Domain List | Browser |
| 1128592 | Fixed an issue in the Data Browser when attributes were defined as numeric, displayed with decimal places | Browser |
| 1128593 | Data Browser will no longer display MSLINK when it is defined as a Primary Key | Browser |
| 1128595 | Attributes for WM_VALID (startdate, enddate) is now displayed. | Browser |
| 1128596 | Removed the limit for Domain List entries in the Data Browser | Browser |
| 1128599 | Fixed a Fill problem converting from DGN to DWG in OpenCities Map For Finland | DWG |
| 1128673 | Fixed Query WFS by Fence or View with EPSG:26916 | Coordinate System |
| 1129741 | Annotation sub-feature was moved during posting to the database | Spatial |
| 1129850 | Replaced the GEOZONE MDL so that it will install with the CONNECT Editions | Installation |
| 1129915 | Fixed an Unrecognized property type dateTime error | DGN2DB |
| 1130028 | Fixed an issue where Spatial Query by Fence created from an element in a reference that had a Global Origin not set to 0,0,0 produced an error | Spatial |
| 1130045 | Fixed an issue were DGN2DB would create an incomplete .DAT file | DGN2DB |
| 1130162 | Corrected some typos in the messages during Import / Export | Interoperability |
| 1130811 | Fixed the Overwrite Placement Method to update operation dialog boxes | GSA |
| 1130893 | Fixed a problem when Line Features also included a line-string Element | XFM |
| 1130940 | Fixed the line break problem "\010" when followed by a number | PBA |
| 1130964 | Cleaned-up the code in Map Manager/Print Preparation | XFM |
| 1131061 | Updated the GeoECSDK's postgres client | PostGIS |
| 1131135 | Corrected an Export issue in the new Export Feature Definitions code | Export Feature |
| 1131442 | Renamed the tools in the Feature Inference Group (from Tech Preview names) | Feature Inference |
| 1131454 | Corrected an issue where a Feature in a Reference would not add to a Selection Set | Reference |
| 1131595 | Corrected a File Close issues for Session Feature lists | XFM |
| 1131601 | Corrected a problem in the GSA where the Path was not being updated | GSA |
| 1131869 | Fixed an Exception issue that occurred when you clicked on the Graphical Source a second time | File Geodatabase |
| 1132120 | Added the subfolder 'vue' to the .exe.config files for all Map editions | Configuration |
| 1132346 | Cleaned-up some code where the Print Frame Selection was not clearly arranged | Print Preparation |
| 1132385 | Renamed the tools in the Technology Preview list | Installation |
| 1132837 | Fixed a problem where the Polygon Collection area pattern cell color was not right | Symbology |
| 1133082 | Updated the Help document for the MS_GEOIMPORT_PATH and MS_GEOEXPORT_PATH variables | Help |
| 1134256 | Cleaned-up the code that caused an exception during model change event | XFM |
| 1134720 | Corrected a problem in ArcGIS ad hoc connections that do not require username or password | ArcGIS |
