| Reference | Summary Description | Keyword(s) |
| 292349 | Workspace Manager Valid Time support is not working accurately and consistently | Workspace |
| 293337 | When GSA Re-registers features in an Oracle Spatial Graphical Source, it does not pick up size changes to existing properties. | Bentley Geospatial Administrator |
| 335301 | Enhance the Map Manager to allow overriding only specific symbology attributes | Map Manager |
| 345375 | Slant Angle not supported by Symbology and Labeling. | Map Manager |
| 345817 | Promote by choosing the "MS/XFM polygon collection" fill area result to an invalid geometry type | XFM |
| 345820 | To promote from "XFM Collection" or a "MS Polygon Collection" user need to use selection set or fence | XFM |
| 347057 | During spatial query, non-coplanar polygons that are members of polygon collections are not filled as expected. | Interoperability |
| 347489 | In reference, by changing model, we lose Polygon collection display. | XFM |
| 349156 | Features queried from some WFS server are queried with inverted X and Y coordinates. | WFS |
| 350349 | Angles for linear hatching in XfmSettingsP are read in degrees and written back in radians when using xfmMapLayer_getStyle xfmMapLayer_setStyle | API |
| 350995 | Memory Leaks while performing Query Feature | XFM |
| 351406 | cannot override references color table selected where color = number | Map Manager |
| 351408 | Dialog detect badly the RGB color defined | Map Manager |
| 357787 | With map model active and DFS disabled, referencing attachment of 2mb design file takes ~15 minutes. | Map Manager |
| 359033 | After calling xfmMapManager_removeMapFromActiveModel() user interface is not updated to reflect current state. | Map Manager |
| 359037 | Request for new Map Manager API function(s) to turn on/off displayed themes. | API |
| 359911 | Request for xfmMapManager_createMapModel function to respect map definition seed configuration variables. | API |
| 361016 | Request for new Map Manager API function to save the currently active map definition to a new design file. | API |
| 361571 | Tabs display on two lines or more looks blank. | Bentley Geospatial Administrator |
| 368334 | After updating sub-feature geometries, the area and perimeter values of in-memory polygon collections are not recalculated. | API |
| 368827 | Polygon collection range is not computed correctly during ApplyAttributeChanges so the type 106 is written with a bad range causing ghost display. | API |
| 371520 | XFM Feature color defined by numbers in schema are converted to RGB in MS Element Information. | XFM |
| 371589 | The xfmMapManager_getMapModelList function fails when more than one map definition exists. | API |
| 372878 | Customer requests that "Other Elements" layer be automatically added to newly created map definition when DFS is disabled. | Map Manager |
| 377572 | When apply Symbology Fixed Size, the Cell size is different on element with different angle placement defined | Map Manager |
