| 415348 | In thematic definition, the Cell and Text Angle are read as in radians. | Map Manager |
| 420391 | Bentley Map CONNECT Edition now supports connection to a PostGIS Spatial database. The behavior is the same as SQL Server or Oracle Spatial. | Interoperability |
| 420970 | The symbology dialog see CrossHatch definition made in the Bentley Geospatial Administrator as Hatch. | Map Manager |
| 421270 | While importing files, by adding to the Selected Files section it creates duplicate entries. | Interoperability |
| 614748 | To enable Cell Size (scale), the Fixed Size must be set to "True". | Map Manager |
| 734311 | In the initial release of Bentley Map, using the User Defined symbology caused SHP file data to disappear. | Map Manager |
| 799366 | In the initial release of Bentley Map, the drop down list of the ribbon and Command Manager were not synchronized. | Command Manager |
| 806615 | When the Map Manager is enabled, the platform Display Rules engine is now ignored. They were not compatible with the Map Manager resymbolization. | Map Manager |
| 811164 | In Bentley Map CONNECT Edition Update 1, there is a new workflow to work with database properties while using XFM features. The workflow is called "Map Database Linkages". | Interoperability |
| 817355 | In the initial release of Bentley Map CONNECT Edition, when the Map Manager Definition was desabled, the feature turned off in the Map Manager continue to be not displayed. | Map Manager |
| 846325 | In the Bentley Geospatial Administrator, the "Tolerance" parameter has been removed when hatching, crosshatching or patterning a shape. It is now useless in the CONNECT edition. | Bentley Geospatial Administrator |
| 856550 | Deliver Bentley Map CONNECT Edition SDK in a separate download on Software Fulfillment Center. | Programming |
| 857357 | In the initial release of Bentley Map CONNECT Edition, colors were not applying to Text Node elements. | Map Manager |
| 858047 | Sometimes, the Data Browser edits fail to post when connected to SQL Server. | Data Browser |
| 863806 | In the initial release of Bentley Map CONNECT Edition, importing by spatial area = "fence" fails with error "no fence defined" | Interoperability |
| 865306 | In the initial release of Bentley Map CONNECT Edition, display order using the Map Manager does not affect data in .shp and .mif references | Map Manager |
| 871222 | In the initial release of Bentley Map CONNECT Edition, display issues and missing polygon fill for referenced reprojected .shp files | Map Manager |
| 871667 | In the initial release of Bentley Map CONNECT Edition, toggling on or off a layer can sometimes cause a crash | Map Manager |
| 875635 | In the initial release of Bentley Map CONNECT Edition, closing a file sometimes causes a crash on Windows 7 | Application |
| 875686 | In the initial release of Bentley Map CONNECT Edition, using the promote command on a label causes a crash | Application |
| 875799 | In the initial release of Bentley Map CONNECT Edition, Map Manager layer display control interferes with level display control when Map Manager is disabled | Map Manager |
| 884309 | In the initial release of Bentley Map CONNECT Edition, searching for features by spatial location using the fence throws an exception | Map Manager |
| 886604 | In the initial release of Bentley Map CONNECT Edition, Export to Shapefile messages show as "Import" in the resulting log file and Message Details | Interoperability |
| 886609 | In the initial release of Bentley Map CONNECT Edition, exporting to .shp file causes error "The MicroStation element could not be converted to an OGC type geometry." in some situations | Interoperability |
| 888660 | In the initial release of Bentley Map CONNECT Edition, using the Discard Changes command with the Refresh Local Instances option does not refresh the local instances | Interoperability |
| 893601 | In the initial release of Bentley Map CONNECT Edition, re-registering a spatial feature to add a sequence does not hide the primary key column | Bentley Geospatial Administrator |
| 901778 | The angle from element option doesn't work in polygon hatch fill type | Bentley Geospatial Administrator |
| 910672 | After editing a point text feature property in the Data Browser, the features is relocated when queried back into the design file. | Interoperability |
| 910718 | In the initial release of Bentley Map CONNECT Edition, the polygon “Plane Constraint” drop box displays codes instead of labels | Bentley Geospatial Administrator |
| 910758 | Invalid geometry error after editing SQL Server linear feature in the Data Browser application. | Data Browser |
| 914710 | The default log file name has changed from gg.log to map_connect.log | Application |
| 916960 | SQL Server error related to forceplan hint encountered when locking features | Interoperability |
| 919399 | In the initial release of Bentley Map CONNECT Edition, import Shapefile results in "incomplete coordinate reference" message with files using the "TX/2011-CF" coordinate system | Interoperability |
| 920403 | Polygon boundary placement mode dropdown value it is not refreshed when the placement tool is restarted | Command Manager |
