The following issues have been corrected in the OpenCities Map CONNECT Edition Update 16 (10.16.00.60):
| Reference | Summary Description | Keyword(s) |
| 748777 | Added Collection to utilize the Align text annotation option when placing text sub-features | GSA |
| 1130893 | Fixed Line Features with line-string Element Handler | XFM |
| 1135486 | Fixed Line Break "\010" in placement dialog. | PBA |
| 1138450 | Fixed Text Line Spacing and size when changing drawing scale | PBA |
| 1139263 | Fixed issue with drawing elements detected by DFS default rules | DFS |
| 1139536 | Fixed LookUp.GetEntry expression using MS-Excel | Inference Rules |
| 1139586 | Fixed Style Scale is not applied when Style is defined ByLevel | Line Style |
| 1139587 | Fixed Level issue when promoting element from reference file | Inference Rules |
| 1140128 | Allowed parametric cell support to XFM placement method | XFM |
