| Reference | Summary Description | Keyword(s) |
| 414744 | The order of the text in the Edit Text Place holder Values dialog is not correct. | Print Preparation |
| 417365 | Create an associative region element by using the MicroStation tools results to a "Previous version XFM Feature". | Feature Engine |
| 421446 | Stroke Tolerance not honored when Bentley Map is initialized through GEOPAK, as seen in Export to Shapefile. | Interoperability |
| 684261 | The 1,000 feature limit should be addressed while querying the WFS server. | Interoperability |
| 695542 | Export ignores the reference attachment transformation. | Interoperability |
| 710608 | Centroid does not take into account global origin when reporting coordinates. | Feature Engine |
| 721636 | Opening a large DWG file is too slow compared to plain MicroStation. | Interoperability |
