- V8i Update 4 (08.11.09.763)
Reference Summary Description Keyword(s)
416320 When running Bentley Map PowerView in markup mode, certain polygon features are not displaying in the reference file. Bentley Map PowerView
417594 Fixed a crash occurring when Bentley Map is used with the Edit Feature command. The crashes are causing Licensing issues/over usage expenses that are not intentional. Feature Engine
417994 Querying features from a Esri File Geodatabase (GDB) connection with a Where Clause results in an error. Interoperability
418805 Fixed a date problem when the variable MS_DBOLEDBDATEFORMAT is defined Feature Engine
420102 Fixed a problem occuring when importing some GML files Interoperability
420170 SaveAs with merge external attachments should retain XFM options selected when executed from Bentley Map Feature Engine
420393 It is now possible to specify the relative display order of Thematic Classes of a map layer Map Manager
421027 Customer requests that "Other Elements" layer be automatically added to newly created map definition when DFS is disabled. Map Manager
421028 After using xfmFeature_createPolygonCollectionElement hole/solid status cannot be determined. Programming
421032 Added ability to change geometry stroking tolerance at runtime. Programming
421065 The layers definitions are now never deleted even if no instance of this layer is present in the DGN Map Manager
421077 There was an error when using the option "Fixed Size Cell" and the cell had rotation. Map Manager
421084 Request for xfmMapManager_addMapToActiveModel function to respect map definition MS_GEO_MAPDEFINITIONSEED_FILENAME and MS_GEO_MAPDEFINITIONSEED_MODELNAME configuration variables. Programming
421250 An exception occurs during spatial data streaming when an external symbology handler is in use. Interoperability
432633 Added new keyin to execute a saved query file: "MAP QUERY SEARCH FROMFILE " Search
435454 Register Features in Esri File Geodatabase (GDB) that include Domain names with underbar character shows garbled text in Value field Interoperability
472097 Selecting the text styles in the Labeling dialog does not load the corresponding Height and Width settings in the Formatting section. Labeling
473950 Fixed memory leak when turning On and Off features. Map Manager
473980 Scale is not applied Labeling
473982 When exporting labels as Annotation, the Scale is not applied on Fixed Size Text Labeling
474150 While applying Labeling using a newly defined textstyle, the labels are always displayed in Italics, even though it is not set. Labeling
486684 Published i-models from Bentley Map have schema error not allowing MicroStation CONNECT to query or search on feature properties. Interoperability
