| Reference | Summary Description | Keyword(s) |
| 414665 | Resolved the need to use Refresh View after modifying a feature with symbology by using geometric property. | Symbology |
| 417124 | Added the Date data type for the Where Clause. | Thematic |
| 417226 | Error messages were seen when importing a specific GML 3.2.1 dataset. | Interoperability |
| 786275 | Resolved issues seen when exporting with accented characters. | Interoperability |
| 855228 | The feature zoom scale defined in a schema was being lost after deleting a feature. | Display |
| 857159 | After modifying the size of a text sub-feature, all added features disappeared when applying a thematic definition. | Display |
| 857971 | GDI CONNECT key-in was not accepting paths with spaces or variables. | Interoperability |
| 869892 | Removed the hard-coded limit of 20 Methods in a Method Group. | Geospatial Administrator |
| 907895 | Performing a search on an ESRI File Geodatabase Connection procduced an error. | Interoperability |
| 914364 | Map Manager was erroneously creating map definitions when cancelling the Open Map Model dialog. | Map Manager |
| 918165 | Angle from Element was not working on XFM non-collection polygons. | Geospatial Administrator |
| 918929 | Placing coordinates in a print model was creating two leader lines. | Print Preparation |
| 921011 | Some dropdown lists were not appearing in the ribbon interface. | High Security |
| 921619 | Registering a feature geometry type on a PostGIS connection sometimes required a manual selection. | Geospatial Administrator |
| 922022 | Added support for PostgreSQL sequences for PostGIS spatial connections. | Interoperability |
| 922241 | The File > Open command was missing the extension DgnDb Files. | File Operations |
| 923822 | The Attach Reality Mesh option was producing an "Unknown key-in or command" error. | Ribbon |
| 924431 | The Place Legend dialog did not appear at the time of creating a new print model. | Ribbon |
| 929257 | BigInt data type properties were not being registered correctly in a SQL Server connection. | Geospatial Administrator |
| 929498 | BigInt data type values were not being read properly by Analyze Feature in a SQL Server connection. | Geospatial Administrator |
| 931587 | Performing a search on a PostGIS Connection was causing an error. | Interoperability |
| 934117 | The Synchronize to Active Map command was not working for PostGIS connections. | Map Connections |
| 934602 | Setting a Where Clause to Geometric Properties caused an error. | Symbology |
| 934741 | The entry AUTOMATICALLY_GENERATED_BY_ENTITY was shown as an option in the Feature Registration Wizard for SQL Server tables. | Geospatial Administrator |
| 935668 | The configuration variable place holders are not replaced by their values. | Print Preparation |
| 937554 | The Place Feature and Print Preparation tools were not working in High Security mode. | High Security |
| 937606 | The Edit Print Template Properties command caused an error. | Print Preparation |
| 937793 | Bentley Map errored when opening a print model in a *.i.dgn file. | iModel |
| 938091 | An unhandled exception occurred when attempting to create a new Geospatial Administrator (GSA) project | Geospatial Administrator |
| 939459 | Where Clause on property with a short name resulted in an error. | Symbology |
| 939991 | Danish language characters were causing a crash when exporting to Esri File Geodatabase. | Interoperability |
| 940658 | Posting a new feature to a SQL Server connection with an identity-generated primary key was failing. | Map Connections |
| 949421 | A Web Feature Service (WFS) ad-hoc connection was generating an error. | Map Connections |
| 952186 | Buffers were not being created for a linear feature if a geometric length criteria is was defined. | Spatial |
| 952247 | In PostGIS, capital letters in names cause were causing errors. | Map Connections |
| 952248 | A buffer was being created even if no fence has been defined. The None option was not toggled ON by default. | Spatial |
| 952577 | Business properties were not appearing in the layer created by an Overlay operation. | Spatial |
| 952911 | Placement of a cell with PBA origin of X,Y had incorrect PBA values after XY=10,10 key-in. | XFM |
| 961157 | Errors were generated when posting polygon data to eB. | Map Connections |
