| Reference | Summary Description | Keyword(s) |
| 679007 | Data streaming performance is improved with the Map Manager active | Map Manager |
| 718753 | Fixed a problem where graphics where missing when attempting to display Bentley Map Mobile redline (.markupdb) data. | Bentley Map Mobile |
| 739533 | Fixed a problem where Bentley Map would crash when updating or editing text place holders | Print Preparation |
| 753001 | Fixed a problem where export to CSV shifts data to different columns | Interoperability |
| 753002 | Fixed a problem where exporting to CSV from an Oracle named connection adds extra XML data | Interoperability |
| 772965 | Queried spatial data with user defined themes are not all displaying properly and require a layer toggle in Map Manager to be seen | Map Manager |
