| Reference | Summary Description | Keyword(s) |
| 864081 | Grouped Hole elements are not deleted after promoting | Geospatial Administrator |
| 952354 | OpenCities Map PowerView is missing some Ribbon Groups |
Ribbon |
| 1012937 | Dialog boxes need to be resized in the Geospatial Administrator |
Internationalization |
| 1046249 | A specific WFS URL connects, but with only 10 features queried |
Spatial |
| 1046760 | Split two polygons at the same time, but the circle/ellipse gives unexpected results |
3D |
| 1055522 | After a Split Polygon, the symbology display is not updated as expected |
Map Manager |
| 1068507 | XFM Collection Features are only displaying the parent feature as MicroStation Elements |
Map Manager |
| 1068841 | A blocked collection will not split properly |
3D |
| 1068954 | MapCSUtilities dll error is produced when creating a print model from Placed Grids |
Print Preparation |
| 1080997 | The Browse button icon becomes disabled when the Specify Schema (XSD) checkbox. |
Interoperability |
| 1085987 | Unable to Split Polygon on a Rotated View. Seems to only work in a Top View |
3D |
| 1087210 | GSA will hang when trying to use Register Feature from an Oracle 12c Cloud Database |
Spatial |
| 1087491 | In the Add GML dialog box, the Browse button for Specify Schema (XSD) option is not disabled when unchecked |
Spatial |
| 1087622 | Queried WFS Features placed on a DGNLIB level will not toggle on/off via the Level Display dialog box |
Spatial |
| 1089848 | The Exported Annotation label and textbox are overlapping the dialog box in the display |
| 1089972 | VBA Files are missing from the /PrintPreparation/bin folder in the CONNECT Edition |
Print Preparation |
| 1090390 | Map Update 5 does not show the Domain lists in the Data Browser when using an Oracle Spatial connection |
Spatial |
| 1090828 | Incorrect "New Mode" prompt when the Split Polygon tool is active when changing from a 2D to 3D model |
3D |
| 1090967 | For a PostGIS connection, the ECSchema is incomplete while opening the PostGIS Storage |
Spatial |
| 1093396 | In the Export MicroStation Elements tool, a specific polygon collection resulted in a crash |
Map Manager |
| 1093545 | Newtonsoft.Json.dll was missing from GeoECSDKNuGet |
Programming |
| 1093575 | Specific DGN Files would crash when opening from a key-in process |
Crash |
| 1093580 | Register Feature of a PostGIS Connection with a coordinate system defined resulted in a fatal error |
Spatial |
| 1094146 | A specific WFS Connection results in an error "The GML Schema can't be found" |
Interoperability |
| 1094260 | For a specific Feature, the color cannot be applied on a Cell with Text |
Map Manager |
| 1094261 | No Fill Color can be applied to a specific Cell with a Shape | Map Manager |
| 1094341 | A Custom Line Style is not exported as-expected using Export MicroStation Elements | Map Manager |
| 1094424 | Previous-version WFSX files do not open in Map CONNECT Update 5 | Interoperability |
| 1095561 | The Text Placeholder level name is being used incorrectly | Print Preparation |
| 1095944 | ArcGIS data is missing in a Join from a specific dialog box | Map Manager |
| 1096258 | A Polygon Collection Feature with a custom line style and transparency defined creates a crash | XFM |
| 1096396 | Using Export MicroStation Elements from a Map Definition, the Collection Features are not exported to Item Types as-expected | Map Manager |
| 1096904 | Using the Place Feature tool, some features are not recognized as 'new' | Geospatial Administrator |
| 1096920 | The AutoPromote tool creates some features that are unable to Post to a PostGIS database when the auto-generated Sequence ID is enabled | Geospatial Administrator |
| 1097049 | An Annotate Method key-in results in a crash | XFM |
| 1097275 | The Key-in ACTIVATE FEATURESETTINGS rootFeatureName does not change the active transparency or display priority | Map Manager |
