| Reference | Summary Description | Keyword(s) |
| 415002 | In Map Manager, if main root feature is toggled off, sub-features are still shown active. | Map Manager |
| 474703 | Installing Bentley Map breaks Reference > Settings > Adjust Reference Colors functionality. | Installation |
| 490462 | System Fault: bad memory access crash after changing Nesting level in Reference. | References |
| 540558 | Exception occurs when attempting to specify Where clause criteria for querying feature in map for some WFS servers. | Interoperability |
| 559543 | Unable to extract package of Bentley Map 08.11.09.763 on Windows 10. | Installation |
| 567191 | Opening the Symbology dialog crashes Bentley Map 08.11.09.763 Chinese Simplified version. | Map Manager |
| 586475 | Undo/Redo after Copy Element and Change Model causes element to be 'frozen' from additional commands. | Edit Feature |
| 586915 | Polygon collections containing arcs are displayed incorrectly after being queried from SQL Server spatial database. | Interoperability |
