| Reference | Summary Description | Keyword(s) |
| 884312 | Opening a saved query with spatial extents resulted in the OK button not being active. | Map Connections |
| 937598 | Some SQL SELECT statements returned no rows for features with database linkages | Database |
| 940267 | Switching between print and map models would cause display issues. | Display |
| 943320 | In specific situations, unexpected results occurred when using the Thematic display Where clause with Geometry_Length and Geometry_Area. | Display |
| 946863 | When generating classes without properties defined, an error would occur. | Display |
| 946867 | When generating classes for cells, the preview icon incorrectly displayed two cell instances. | Display |
| 951901 | The Join dialog was missing PostGIS sources. | Interoperability |
| 974850 | PostGIS schema discovery was halting when unsupported geometry types were encountered. | Map Connections |
| 977480 | Feedback messages from the Data Browser Save As operations were freezing on large datasets. | Data Browser |
| 978561 | Under certain conditions, reusing map model names did not attach the Default model as expected. | File Operations |
| 979393 | The PRINTPREP WRITEXMLCONFIG key-in was generating an error. | Print Preparation |
| 980509 | Some Advanced Searches were creating an error. | Map Connections |
| 982757 | Topology operations were not displaying correctly in files opened after closing another file. | Topology |
| 988177 | Initial Values for firstNumeric type was not working as expected for numbers over six digits. | Geospatial Administrator |
| 995901 | Creating an overlay from imported SHP polygons was creating an error. | Spatial Analysis |
| 999259 | The key-in PRINTPREPARATION WORKFLOW RUNBATCH was not working as expected. | Print Preparation |
| 999804 | Referenced XFM features were disappearing from the view after Make Active for Edit. | Display |
| 1001880 | DFS was not recognizing a MicroStation mesh element. | Display |
| 1001975 | Check Gaps dialog behavior and appearance has been corrected. | Display |
| 1003333 | The ribbon group for scalable terrain models was missing. | Interface |
| 1003732 | DWG files with Polish characters were not referencing properly. | Interoperability |
| 1004842 | When a map defintion was present, deleting features required the view to be refreshed. | Display |
