- CONNECT Edition Update 16.3 (10.16.03.12)
The following issues have been corrected and/or added to the OpenCities Map CONNECT Edition Update 16.3, version 10.16.03.12, dated June 02, 2022.  Review your Service Request and the Reference # below to see if it has been fixed in this release.
Reference Summary Description Keyword(s)
751290 Request to support both simple geometry and geometry collections when matching graphical sources to existing XFM features GSA
751298 In Save As/Batch Convert, add options to apply inference rules, legacy rules to promote DFS to XFM feature DFI
751302 Request key-ins to close and/or toggle Command Manager dialog Command Manager
751307 Connect existing feature to graphical source GSA
751312 Please provide a SQL-level extension mechanism PostGIS
751393 Translate Stella Map to English Stella
751447 By Default, request for the Command Manager dialog not open on starting Command Manager
751939 Same template assigned for Text and Shape element Print Preparation
751943 MS_GEOXFM_SRC_SCHEMA variable not pointed properly to StellaMap.xml Configuration
751946 If linear feature is cut in two, other part loses feature data Topology
751948 Using MS_GEOXFM_BORDER_SCALE_DOMAINLIST_FILE variable causing scaling issue in Imperial units Print Preparation
751950 Create area feature from elements creates an Exception Map Ultimate for Finland
751952 An exception occurs after editing the property type of a matched feature GSA
751954 While matching XFM to spatial features the registration wizard can show incorrect information if the process skips through the screens using Back and Next GSA
751959 Path for Workset was ignored in a specific Schema GSA
751962 In Save As/Batch Convert, remove Tags/Items during promote DFS to XFM feature XFM
751966 Oracle error message displayed when program is loading Map Ultimate for Finland
751975 Exception on Registered Connection where the category name contains an ampersand Spatial
752018 "Error (400) Bad Request" seen in a specific WFS Server URL WFS
752029 Domain values change after selecting a feature and choosing the Edit option when the data type is nchar SQL Server Spatial
752037 Getting an Unhandled Exception with a specific DGN File GSA
752040 Feature class inferred from XFM native collection feature instance has display name with "_Collection" suffix XFM
752043 In the Properties dialog, when viewing component element of a collection feature instance, the parent feature name does not have the _Collection suffix so it has same name as component feature XFM
752052 MS_GEOIMPORT_PATH and MS_GEOEXPORT_PATH are not working with GDI key-ins Interoperability
752058 Export to Shapefile directory causes an Exception with this dataset Interoperability
752065 Changing the schema name after the schema is created can lead to a missing workset GSA
752066 Posted Annotation re-queries in different location from South Africa Spatial Database
752070 Does not export elements from a reference as-expected Export to MicroStation Elements
752078 Export to Shapefile with Russian Text produces bad results Interoperability
752081 Inserted Attribute and double backslash appear in the message center GSA
752084 Topology option is set back to the default value after two consecutive File | Close Preferences
752091 .inc file created on a version 10.7.1 workspace missing values once converted Configuration
752094 Stella Map converting from DGN to DWG filled shapes issue, resolved DWG
752106 Schema Location label is not translated Internationalization
752108 Print models created using custom print templates from a Map Definition produce an empty Map Manager layer list Print Preparation
752112 Getting an Exception from a spatial database query because of a missing cell Spatial
752231 The Add User Workset description is not considered in this case GSA
752232 For Point-Text features, the GSA Schema-defined Scale value is not recognized Symbology
752238 DWG output of the print model does not show the legends text Print Preparation
752432 Specific GML issue during import GML Programming
752530 Load by Selection to Data Browser not showing valued (spatial databases-only) Browser
752582 Modify the Exception message on Export to GML when there is no Coordinate System Interoperability
752689 It should preserve the dialog open/close status as it does for positioning and sizing Command Manager
752924 Application freezes when placing a road feature using the second segment mode XFM
752995 Detect features without Apply Edits service and return them as read only features ArcGIS Server
753188 Stamp functionality not working Print Preparation
753274 Incorrect display of Topology category in Preferences Preferences
756050 Two vertex Line String results to an Exception using Copy Parallel XFM
763278 Rename Schema Workspace / Workset exporting old name GSA
766718 Visibility toggle not honored as user-defined in Map Manager Map Manager
767233 Error messages about missing setting files Map Ultimate for Finland
767377 Exception thrown on Detach Reference file with specific dataset Reference
774268 Legend window does not appear for specific DGN Print Preparation
782452 DGN2DB with reference files causing Error: The Property 'DGN_ID' is read only DGN2DB
782676 Request to add other types of linear elements available for leader-line annotation Place Feature
782689 When placing Leader-line Annotation, the resulting text is upside down Place Feature
785408 Specific file throws and Exception after zoom in-out, and pan view View Commands
785469 An ESRI File Geodatabase registered connection operation fails FGDB
787529 .NET Framework Error on File Open Programming
796608 Fence File on Polygon Collection with Pattern Area give unexpected results XFM
798565 Drop XFM Polygon Collection in Map - "Duplicate current version XFM root-feature element" detected XFM
799286 DGN File will not stay open in Map Update 16, Exception thrown Internal Error "Unknown" XFM
808101 Running Validate Topology on a specific DGN causes Map to throw an Exception Topology
813558 Legacy DFS variable not working anymore as expected, fixed XFM
814782 Provide API to connect to graphical source without showing any forms Programming
814876 GSA-created features matched to a PostGIS database are not querying back into Map PostGIS
814892 The GSA is not displaying feature properties after a spatial feature has been matched to an existing XFM feature GSA
822976 Generate Zone tool from geozone.mdl always result to 5 distance offset MDL
824653 Occasional Exception thrown when switching workspace and file Configuration
847222 When Deleting a feature from the Tree List, it should also update the Command Manager list XFM
847863 Copying a specific feature instance results in Map becoming unresponsive XFM
849143 Adding a Date-tick property results to an Exception with this dataset GSA
849677 Multiple errors when exporting polygon layers to File GeoDatabase Interoperability
851911 Spatial Feature Matching to XFM Features works with Point Cells, but not Point Text Place Feature
859762 Buffer operation, Overlay operation throwing an Exception Analysis
864633 Add support for OpenCities Map in non-graphic mode, like in V8i XFM
867103 Both Domain Name and ID are visible in the Data Browser Browser
881912 Feature list is not updated correctly in a specific workflow XFM
883298 Edit Properties results in an unexpected Text Annotation Size XFM
884206 Enable support for FME 2022 FME Import/Export
889137 Placing or Deleting lines takes over a minute with a specific dataset XFM
894330 Enable DYNAMICBASE for the nnn.EsriFileGeoDatabase and OrgStorage .dlls  Flag
895135 Values are not inferred when using RGB values from custom line styles XFM
901997 Remove WMTS from the Tech Preview in OpenCities Map Update 16, will publish in Update 17 Tech Preview
Keywords:
* DGN2DB - Command line graphical to spatial database tools
* DFI - Dynamic Feature Inference
* FGDB - ESRI File Geodatabase
* GSA - Geospatial Administrator
* MDL - MicroStation Development Libraries
* XFM - XML Feature Modeling
