- V8i Update 6 (08.11.09.834)
Reference Summary Description Keyword(s)
413850 In Oracle, post fails after splitting or copying a spatial feature with a registered id generator. Interoperability
415093 When querying Oracle Spatial on level existing in associated dgnlib file, it adds feature on ghost level instead of existing one. Interoperability
415501 Import or attach shapefile with accented character attributes values display badly. Interoperability
421390 When posting to Oracle, features utilizing MSLINKs cannot have null values for the associated CLOB field. Interoperability
491998 Show Spatial Extents functionality does not respect SRID transformations. Interoperability
492956 Label placed with Element Orientation set to "Element Relative" should honor a polygon's angle orientation, not the view orientation. Labeling
561771 Create texture tool enhancements for shared textures. Feature Engine
562112 Shared texture support in Oracle Storage and Bentley Geospatial Administrator. Feature Engine
589823 Unable to edit/paste an entire selection. Data Browser
615824 Attempting "Save As..." to DWG format fails when Type 106 polygon collection elements exist. Interoperability
618981 Export from XFM collection feature to Esri Shapefiles (*.shp) gives two incomplete SHP files. Interoperability
623812 Request for a new API function to optionally create a connection with the toggle "Synch With Active Map" set to off. Programming
624390 Splitting Polygon feature throws 'duplicate key' error on post. Interoperability
626226 Graphical source connection is lost when GDI_KEEP_CONNECTION_OPEN_ON_FILE_CLOSE is defined and _USTN_REQUIREDAPPS configuration is used. Interoperability
628744 Re-registering a SQL Server feature does not update its tolerance. Bentley Geospatial Administrator
634680 Polygon Collection produces ghost features when reprojected from Reference model. Feature Engine
635826 Posting ad hoc SQL Server features fails with 'SqlTransaction has completed' error. Interoperability
639119 User lost Map Definition by detaching file. Map Manager
642563 Make Active for Edit, Stop Editing turns on all Layers and prohibits them from being turned off. Map Manager
643181 Merge Ref into Master turns on all Layers in Map Manager and prohibits them from being turned off. Map Manager
645727 Use of LocateOp.ScanAtPoint fails when specific geographic coordinate systems exist in active/reference files. Programming
