| Reference | Summary Description | Keyword(s) |
| 61513 | [Print Preparation] Frames from a dgnllib pick list are not displayed in a sorted order | Print Preparation |
| 68417 | [Labeling] Offset for labels in Map Manager are incorrectly translated in the a print model. | Labeling |
| 78383 | [FGDB] An Esri File Geodatabase feature with a composite relationship cannot be queried: “An invalid SQL statement was used.” | FGDB |
| 124934 | [Interoperability] Esri File Geodatabase polygons with curves not displayed properly | FGDB |
| 129979 | [Labeling] Unhandled exception in Labeling when illegal text weight is inserted | Labeling |
| 130085 | [Symbology] Invalid scale display in Symbology after specific steps. | Map Manager |
| 130403 | [FGDB] After an Esri File Geodatabase export unneeded and empty files are created for features that were not selected | FGDB |
| 131461 | [Interoperability] Export by spatial area view is not returning the correct results | Interoperability |
| 147039 | [Administrator] Updates made to some collection feature class icons | Bentley Geospatial Administrator |
| 148534 | [Printing] When printing to PS some underlined text will display poorly | Printing |
| 148537 | [Printing] Crash in Bentley Map when printing to PS with specific files | Printing |
| 148639 | [Oracle Spatial] DGN2SDO is not properly creating scripts for data with multiple sub feature annotations | DGN2SDO |
| 149856 | [SQL Server] Exception when opening GDB version 10.2 Patch1 release (The given key was not present in the dictionary.) | SQLserver |
| 150766 | [Map Manager] "NOT LIKE" or "NOT IN" cannot be used as operator as they are missing in the Criteria Editor | Thematic |
| 151375 | [Administrator] Store Last Value does not retain the last value when the comboBox property is in the Edit dialog. | Bentley Geospatial Administrator |
| 151466 | [FGDB] Exporting an XFM linear collection feature to Esri File Geodatabase results in an error | FGDB |
| 151822 | [XFM] Default scale defined in Bentley Geospatial Administrator is not always honored | Bentley Geospatial Administrator |
| 152854 | [Labeling] Added the ability to select a database property to determine the height and width of a label | Labeling |
| 157317 | [Labeling] Labeling Text Justification has wrong default value | Labeling |
| 158137 | [Interoperability] Connect to Graphical Source name by key-in does not work for WFS and Esri File Geodatabase connections | WFS, FGDB |
| 159509 | [WFS] WFS Servers are not handing all gml standard properties in query | WFS |
| 161191 | [Thematic] A crash occurs when you try to open a DGN file that contains a pre-defined .theme in a Map Model | Map Manager |
| 166700 | [Oracle Spatial] DGN2SDO is prematurely terminating and failing to process some batch files | DGN2SDO |
| 166926 | [MicroStation Compatibility] SaveAs/BatchConvert DGN/XFM into DGN | MicroStation Compatibility |
| 167487 | [SQL Server] Feature registration is not consistent with feature naming using SQL Server | SQL Server |
| 168907 | [Interoperability] View queries containing nonspatial features and spatial features are failing | Interoperability |
| 169210 | [Map Finishing] Enhancements made to enable better printing results | Map Finishing |
| 172628 | [Oracle] Arcs that are part of a polygon will not post | Oracle |
| 172904 | [MicroStation Compatibility] Request for the ability to delete a Bentley Map XFM feature instance while in MicroStation | MicroStation Compatibility |
| 172905 | [MicroStation Compatibility] While in MicroStation, want to be able to "Drop" a Bentley Map XFM feature instance as MicroStation elements | MicroStation Compatibility |
| 175837 | [Oracle Spatial] In some scenarios programmatically modifying a feature forces an unwanted new feature post attempt | Interoperability |
| 179116 | [SQL Server] Feature registration naming should show XFM Feature Name and Display Name in the registration wizard with the DATABASE name and the SCHEMA name removed. | SQLserver |
| 186964 | [MicroStation Compatibility] Request to change default XFM option in the Save As… V8 options dialog | MicroStation Compatibility |
| 194297 | [Scripting Engine] Newly created levels in a script disappear after closing and reopening design file. | Scripting |
| 195514 | [Interoperability] Memory not being released by Bentley Map Mobile Publisher results in Bentley Map crash | Interoperability |
| 200030 | [API] Functions xfmViewLabelDef_setCharacterHeightFormatString and xfmViewLabelDef_setCharacterWidthFormatString not working as expected. | API, SDK |
| 200993 | [FGDB] Esri File Database with Domains result to an exception and crash after by removing connection or closing file | Interoperability |
| 203361 | [Administrator] [Esri File Geodatabase] Pre Bentley Map (SELECTseries 4) XFM schemas cannot be upgraded to add Esri File Geodatabase graphical source connection | Bentley Geospatial Administrator |
| 204382 | [Workspace Files] The delivered TextStyles.dgnlib contains an unwanted "Origin" saved view. | Workspace |
| N/A | [MicroStation Compatibility] Creation of MicroStation Polygon Collection type to support Bentley Map Polygon Collection in plain MicroStation | MicroStation Compatibility |
