| Reference | Summary Description | Keyword(s) |
| 417103 | Split polygon with holes did not give expected results. | Split Polygon |
| 418920 | Labeling did not consider holes. | Labeling |
| 756637 | Split Polygon was not using existing element for cutting element. | Split Polygon |
| 930029 | Reset button was not working to get out of current tools. | |
| 936973 | Some options in Print Template dialog did not work. | |
| 940961 | Some print preparation post placement tools were not following Element Template settings. | Print Preparation |
| 957653 | Map Join key-in caused errors. | Join |
| 998314 | Custom tab from DGNLib was not showing in Map. | User Interface |
| 999201 | Map was slow to open DGNs with multiple models | Operation |
| 1002662 | Searches performed with Esri file geodatabase resulted in an error. | Interoperability |
| 1007442 | Database operation tools were missing. | Database |
| 1010402 | Domain list values not displaying in combo box properties when using watcher or criteria. | Geospatial Administrator |
| 1021187 | Attached images did not display in Raster Manager dialog when re-opening file. | Raster Manager |
| 1022368 | Labeling large datasets was causing an error. | Labeling |
| 1025399 | Unexpected behavior occurred with Area Perimeter Update. | Database |
| 1028088 | Merge Polygon was giving unexpected results. | Merge Polygon |
| 1029569 | Labels were not seen for point features. | Labeling |
| 1035408 | Display of Merge Polygon dialog was problematic. | Merge Polygon |
| 1037711 | The -wr switch was not being passed upon launch. | Geospatial Administrator |
| 1047456 | New features are missing properties upon placement. | Geospatial Administrator |
