| Reference | Summary Description | Keyword(s) |
| 814269 | Border scale defined in XML, with double quotes in DisplayName, results in an exception. | Print Preparation |
| 814826 | Create Viewport Scale keeps built-in scales when it should list only scales user defined XML file. | Print Preparation |
| 818280 | The EXPX file generated when saving an FGDB export parameters cannot be reopened later. | Interoperability |
| 821126 | Some 3D elements are not displayed in ArcScene when exported to FGDB. | Interoperability |
| 853160 | Cancelling Print Preparation causes display issue. | Print Preparation |
| 858062 | Opening the Data Browser dialog can sometimes produce "System.IO.FileNotFoundException: Could not load file or assembly 'System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'" error message. | Data Browser |
| 860936 | Drop Element function used on a cell causes the cell to disappear. | Feature Engine |
| 882153 | Users unable to obtain lock when querying same feature class in different areas. | Interoperability |
