Reference | Summary Description | Keyword(s) |
| 61989 | Bentley Geospatial Administrator does not understand domain list format when it has 7 columns. This is causing the incorrect domain list to be selected. Seems the Bentley Geospatial Administrator does not have provision to support 7 columns and consequently the domain name is not listed. | Bentley Geospatial Administrator |
| 62009 | While drawing over Raster the linear features are not visible. | XFM, Raster |
| 62192 | “Merge Into Master” on modified references it not merge polygon collection features. | Reference |
| 62497 | Changing the grid definition to something that will make the grid smaller (ie smaller text size) will not update the grid instance correctly | Grid |
| 62498 | When dropping a Grid Instance that have labels containing a degree symbol, if the font used in ITALICS, the degree symbol is not displayed correctly. It's replaced by '33/64'. | Grid |
| 62499 | The generated Grid doesn't get exported to Google Earth formats, since it's a single element. On Drop instance, it does get converted to KMZ file. | Grid |
| 62504 | After creating Map Model, features from attached model are not displayed in Views 5-6-7-8 | Map Manager |
| 71288 | Polygon collections with holes do not displays properly (hole filed) in 3D top view | Display |
| 117403 | Hatch Area and Crosshatch Area symbology is not working for imported feature | Interoperability |
| 155269 | Reference merge into master corrupts XFM feature instances | XFM, Reference |
| 156905 | Display of a GML polygon with hole element does not show the hole | Interoperability, GML |
| 160146 | Customer request to update the XFMSYSTEM_ROOTFEATURE_CHANGED event monitor to catch the "Change Text Attributes" command and fire registered event handler. | API |
| 160151 | Request to add an XfmInputValueType of XFMINPUTVALUETYPE_DateTimeFromTicks to complement existing XFMINPUTVALUETYPE_DateTimeToTicks value type. | API |
| 160461 | Enhancements to support ProjectWise Connectors with textures | ProjectWise |
| 195263 | On Exporting 3D XFM Data to Esri File Geodatabase loss of Z values occur | Interoperability, FGDB |
| 200030 | Functions xfmViewLabelDef_setCharacterHeightFormatString and xfmViewLabelDef_setCharacterWidthFormatString not working as expected. | API |
| 200147 | Layer Group is lost when create a new map model | Map Manager |
| 200491 | Referenced Layers are get out of Group Layer when reloading a reference file | Map Manager, Reference |
| 203490 | In Bentley Geospatial Administrator, by upgrading XML schema to Bentley Map (SELECTseries 4), the LineStyles.dgnlib is missing. | Bentley Geospatial Administrator |
| 207159 | Customer requests VBA and C API capabilities to determine hole/solid state for polygon collection members. | API |
| 207410 | Customer requests support for the use of non-coplanar shapes in Bentley Map | XFM |
| 211792 | Use of "Break Element" command multiple times on single feature instance results in duplicate UUIDs. | XFM |
| 215054 | Blanks or Null values in the attributes should be recognized by the ‘Criteria Builder’ and be able to query | Map Manager |
| 215560 | In Bentley Geospatial Administrator, previously registered features are removed when user attempts "Register Features…" again | Bentley Geospatial Administrator |
| 215740 | Customer request ability to copy the geometry of a map element using MicroStation Manipulate copy tool while in MicroStation | Interoperability |
| 219304 | In Bentley Geospatial Administrator, registration and re-registration of views with multiple domains fails | Bentley Geospatial Administrator |
| 223731 | Customer requests the ability to preserve graphical source connection when changing design files. | Interoperability |
| 241218 | Customer requests the ability to preserve graphical source connection when closing design files. | Interoperability |
| 246689 | Customer requests the ability to sort the layer names in Map Manager and Command Manager entries, | Map Manager, Command Manager |
| 267419 | Promote Text element to XFM element does not apply Text Style properly | XFM |
| 293611 | While in MicroStation and fence copying XFM elements from reference to master, fence clip modes must be honored | Interoperability |
| 312418 | Exporting the features from the sorted layer group does not follow the original display order. | Interoperability |
| 314051 | A crash occurs when exporting to Esri File Geodatabase format. | Interoperability, FGDB |
| 317282 | Cannot query/post to spatial database from a file that uses the projection UTMZN-BF | Interoperability |
| 325665 | Drop XFM by Fence Clip closing hole for XFM polygon collection with hole | Interoperability |
| 328065 | In Bentley Geospatial Administrator, Operation Failed on registered feature for Esri File Geodatabase and requiring application process to be killed | Bentley Geospatial Administrator, FGDB |
| 329498 | Request to be able to assign Map Texture to a Complex Shape element. | Textures |
| 335295 | Save as merge External Attachments with XFM feature resulting to a crash | XFM |
