Freeware - Utilities - Applications - Programs
Disclaimer - The following applications (also known as programs, utilities, and freeware) are provided as is and do not come with support.  Bentley Systems Inc., and the author of this programs assume no liability for damages direct, indirect, or consequential, which may result from the use of this programs. Use these programs at your own risk.  Do not assume they have been tested to work on all versions of product.
[[- Learning Resources]]
- Auto update Editing initial values (Sync1 MDL)
[[- Centroid text to shape (VBA)]]
[[- Change feature elevation (VBA)]]
- Convert plain text to XFM and propagate text string to polygons (Two VBAs)
- Create schema from Shapefiles (Schema Register EXE)
- Export text string and Element ID (TextNodeToTextFile VBA)
- Extended properties (xProps MDL)
- Load business properties from text strings (text2xfm VBA)
- Planarize 3D polygons (MDL)
- Setting A Default Level for Reference attachment (VBA)
- Show XMF properties on tool tips (MDL)
- Symbology Integrator (EXE)
[[- Utilities from Elivagner Barros]]
- XFM attribute query (Feature Query VBA)
