- Fix Cannot access a disposed object error
In the event that the Geospatial Administrator throws you a Cannot access a disposed object  error, you can try the following:
1. Ensure all .NET components or JAVA components are up-to-date.
2. Review the Windows Event Viewer log file to see if there are any errors listed.  Then try to resolve those errors.
3. Reinstall the software after cleaning all registry license and software keys for installed products.
