You can see and operate Relity Mesh Attachment in desired view by using Level Display functions
Steps
- Before attaching attachment create a new level and make sure that is active level. (You can use one of existing levels if needed)
- Attach reality mesh
- Activate any other level
- Turn display off the level wich contains reality mesh attacment, from Level Display with the settings View Display while using the view that you dont want to see attachment
