- Changing project and workset information
When evaluating an OpenCities Map project, you often do so in a test environment rather than in production.  When it's time to move into production, simply update the:
- Project Name, Workspaces Root Directory in the Project Information tab
- Name and Base Source Dir in the Workset tab
Once exported, the workspace metadata will be created in the production folders specified above.  Note that updating or editing a Map schema will not impact or change your feature definitions.
