- Load properties from text strings (text2xfm VBA)
The attached zip file includes a VBA text2xfm.mvba with documentation that describes how to load business properties from text strings. The text (or text node) will become an XFM feature and the property is loaded with the text string (and rotation). If the property already exists, it is updated. The result can be exported to a point SHP file including the text property (and rotation).
Note: a XFM schema is not required.
This macro runs on V8i, CONNECT, 2023 and higher with OpenCities Map Ultimate, Advanced and PowerView.
The tool is available for download via OpenCities Map Files:  Text to XFM property
15 July 2026 v1.11 Implemented small fixes.
Disclaimer - This application is supplied as-is and does not come with support. Bentley Systems Inc., and the author of this programs assume no liability for damages direct, indirect, or consequential, which may result from the use of this program. Use this application at your own risk.
