How to create a Custom Cell Symbology
- Open any DGN file and draw a desired shape for a cell.
- Choose Define Cell Origin option and add a data point. Choose element selection and select all of the shape.
- Select option New in Cell library, then new shape will be added after assigning name and selecting ok.
- Open Geospatial Administrator, navigate to Cell feature and assign Cell Name.
- Save and Export schema, run the workset and try adding a Cell feature.
