- Difference between Remove in the Map Manager and Delete
When creating a buffer on any feature class, it results a new feature class being created in Map Manager.
Using the Remove option will remove the feature class from the Map Manager, and turn off the display of the associated features.   The features themselves are not deleted.
Using Delete will delete the graphics and show feature class name in grey in the Map Manager.
