The following resources can be used to help with VBA programming in OpenCities Map:
Standard Operation Library
xfmStdOpsLib.mvba is the Standard Operation Library delivered with Bentley Map V8i as well as OpenCities Map CONNECT Edition. This is a library of pre-defined methods used to manipulate XFM features. Look for this file in the following installation folders:
CONNECT Edition: ...\Program Files\Bentley\Map CONNECT Edition\OpenCitiesMap\vba\
V8i: ..\Program Files (x86)\Bentley\MapEnterprise V8i\MapEnterprise\vba\
Examples
- Example.mvba is designed to be used with the geo_example designer and geo_example_dialogs which is delivered and installed. Look for the following in the workspace(s) folders:
CONNECT Edition:
...\WorkSpaces\geo_example\xml\schema\geo_example.xml
...\WorkSpaces\geo_example\WorkSets\designer\vba\example.mvba
V8i:
...\WorkSpace\Projects\Examples\Geospatial\geo_example\xml\schema\geo_example.xml
...\WorkSpace\Projects\Examples\Geospatial\geo_example\designer\vba\example.mvba
