If you receive Fatal Error. Could not create a .ma file for an Addln: file:///C:/Program CONNECT Edition/MapTheme. for example:
This error can occur if the AddInLoader1.0 folder is missing from Path = “C:\Users\user.name\AppData\Local\Temp\Bentley\MapTheme\10.0.0\”
To correct the problem, please create a folder named as AddInLoader1.0.
Note: Here MapTheme could be MapPowerview or MapAdvanced or MapUltimate
