The table below is an overview of the tested and supported operating systems for OpenCities Map. Information on operating system support for each version of OpenCities Map can be obtained from the versions Readme file under the topic Installation Requirements.
Note: OpenCities Map generally follows MicroStation. For MicroStation supported operating systems, please refer to the following https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0108039
| Product | Version |
Operating System |
| OpenCities Map CONNECT Edition x64 (Update 7) |
10.07.00.62 |
Bentley does not support its software running on Microsoft operating systems versions that Microsoft has "retired". For more information see Microsoft's application retirement policy and the Bentley Application Support Lifecycle.
| OpenCities Map CONNECT Edition x64 (Update 3) |
10.03.00.23 |
Windows 10 (64-bit) Windows 8.1 (64-bit) Windows 7 SP1 (64-bit) Windows Server 2012 (64 bit) |
| OpenCities Map CONNECT Edition x64 (Update 2) |
10.02.00.18 |
Windows 10 (64-bit) Windows 8.1 (64-bit) Windows Server 2016 (64-bit) Windows Server 2012 (64-bit) |
OpenCities Map CONNECT Edition x64 (Initial Release) (Update 1) |
10.00.00.30 to 10.01.00.22 |
Windows 10 (64-bit) Windows 8.1 (64-bit) Windows 7 (64-bit) Windows Server 2012 (64-bit) Windows Server 2008 (64-bit) |
| Bentley Map V8i (SELECTseries 4) |
08.11.09.882 to 08.11.09.908 |
Windows 10 (32-bit and 64-bit) Windows 8.1 (32-bit and 64-bit) Windows 8 (32-bit and 64-bit) Windows 7 (32-bit and 64-bit) Windows Server 2008 (32-bit and 64-bit) Windows Server 2003 (32-bit and 64-bit) |
08.11.09.713 to 08.11.09.864 |
Windows 10 (32-bit and 64-bit) Windows 8 (32-bit and 64-bit) Windows 7 (32bit and 64-bit) Windows Server 2008 (32-bit and 64-bit) Windows Server 2003 (32-bit and 64-bit) |
08.11.09.503 to 08.11.09.666 |
| Bentley Map V8i (SELECTseries 4) | 08.11.09.443 |
Windows 7 (32-bit and 64-bit) Windows Vista (32-bit and 64-bit) Windows XP (32-bit and 64-bit) Windows Server 2008 (32-bit and 64-bit) Windows Server 2003 (32-bit and 64-bit) |
| Bentley Map V8i (SELECTseries 3) |
08.11.09.91 to 08.11.09.107 |
| Bentley Map V8i (SELECTseries 2) |
08.11.07.425 to 08.11.07.434 |
| Bentley Map V8i (SELECTseries 1) | 08.11.07.113 |
Windows 7 (32-bit and 64-bit) Windows Vista (32-bit and 64-bit) Windows XP (32-bit and 64-bit) Windows Server 2008 (32-bit) Windows Server 2003 (32-bit and 64-bit) |
| Bentley Map V8i (SELECTseries 1) | 08.11.07.87 |
Windows 7 (32-bit and 64-bit) Windows Vista (32-bit and 64-bit) Windows XP (32-bit and 64-bit) Windows XP Tablet PC Edition, Windows Server 2003 (32-bit and 64-bit) |
| Bentley Map V8i | 08.11.05.49 |
Windows Vista (32-bit) Windows XP (32-bit) Windows Server 2003 (32-bit) |
Bentley does not support its software running on Microsoft operating systems versions that Microsoft has retired. More information on Microsoft's application retirement policy you can read in the article Microsoft Lifecycle Policy and the Windows Lifecycle Fact Sheet.
For similar information on Bentley products, refer to the Bentley Product Support article.
