The attached VBA provides simplified method of setting Default level to reference attachment.
Workflow:
- Download attached refsetlevel.zip file , extract it and copy VBA file into C:\ProgramData\Bentley\Map CONNECT Edition\MapUltimate\Configuration\Organization\Macros.
- In OpenCities Map CONNECT edition, keyin Macro as: VBA RUN [RefSetLevel]Main <DgnFileFullpath>.
For example: Macro VBA RUN [RefSetLevel]Main C:\ProgramData\Bentley\Map CONNECT Edition\MapUltimate\Configuration\WorkSpaces\geo_example\WorkSets\designer\dgn\work.dgn
- It should reflect a message as "Reference Attached".
Note: If you have used custom configuration and selected different hard disk partition than 'C Drive' while installing OpenCities Map, then please copy VBA file into macros folder under the same hard disk partition as installation.
communities.bentley.com/.../refsetlevel.zip
Disclaimer - This application is supplied as-is and does not come with support. Bentley Systems Inc., and the author of this programs assume no liability for damages direct, indirect, or consequential, which may result from the use of this program. Use this application at your own risk.
